I just turned on my laptop and tried to print on my brother mfc-490cw printer wireless. It reads "offline." Any help?
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
I fixed this problem!
I have Windows Vista, and went to the printers and faxes folder in the control printer.
I clicked on "add a printer" at the top of folder, and the Windows program searched for all available printers. It found the one already in the system, and then basically found it again; it had the brother mfc 490cw label and the IP address.
I clicked on that one, and it basically it added the printer all over again. I clicked on "print test page," and it came out like it was supposed to. I printed several of my own pages just to make sure, and they came out too!!
I don't know what went wrong with the original printer addition or why it happed (it's still there, just not as the default; the newly added printer is now the default.). I also don't know if the same problem will happen again, but, if it does, I guess I'll just keeping adding the same printer all over again until the folder overflows!!!!
Hope this helps. It didn't really explain why this happens, but at least it got the printer working again (for now at least!!!)
I also fixed this problem which occurred after receiving faxes although that might be unrelated. My operating program is Vista on a Sony laptop.
1. Shut down MFC-490
2. Control Panel - Printers - Highligt MFC-490 - Delete Printer
3. Start - All Programs - Brother - MFC-490 - Uninstall
4. Turn on MFC-490 - configure wireless according to manual
5. Reinstall MFC-490 Drivers/Software
6. Start - All Programs - Brother - MFC-490 -Installation Diagnostics
7. All items should show connected
8. Control Panel - Printers - Highligt MFC-490 - Hold mouse pointer on it. Should show READY. Right click and print Test Page
PS I followed Best Solution to the extent of "uncheck enable SNMP"
Double click the printer in Printers and Faxes, when the dialogue box opens, choose Printer, then click 'Connect' or uncheck 'Use Printer Offline.'
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
And/Or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Same problem, appears to be related to Brother sleep mode. Using the Connect / uncheck "User Printer Off-line" doesn't seem to work.
I have the same problem some one help pls
My Brother MFC-490CW Printer - wireless on my Vista laptop is also offline, when I re-started the computer, it was the first 5 minutes on-line and after I while is was offline again!
The Scanner works perfect.Also an XP machine in my network and works perfect.
I re-installed the software, deleted the printers. Nothing helped.
Who can help me?
I have exactly the same problem. I deleted the printer, re-installed and got some kind of error message about firewall. It says that the installation was completed successfully, however, I still have the same problem. The print file sits in the print queue and the printer status shows that it is 'off-line'. Can't seem to change the status from 'off-line' to 'online'. This all started happening yesterday, 04/12/2009.
I tried the solution. The only problem is that it doesn't let me uncheck ""; it's not checked to begin with. And there's a "connect" option, only it's shaded, not an active menu option that it will let me choose. Now what???
My desktop prints fine but my laptop says that the printer is off line. I can't find anything about it in the manual either. Please Help.
MFC-490CW is offline
had machine serviced now it does not work
MFC-490CW
