Do have the driver for the IBM? then use it. if you don't, then what about serial port or RS232. get a converter that is serial to usb converter with the driver will allow you to use your usb through serial port.
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
If that doesn't fix it you might have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
If your computer doesn't have an audio device, you can't download one. You'll have to get a piece of hardware that supports audio. Go to geeks.com, or amazon.com and get one of the USB sound cards. When it arrives, plug it in to a USB slot, install the drivers, and connect the output to some powered speakers or headphones.
Hi Jeff Gheng here, do you installed Flash and Shockwave Player? if not kindly install first.. try to download in your browser and then install. restart your computer and log in to your Facebook Account, if doesn't work, you have a slow connection... try it later.... Best Regards!
Plugging it into your computer should be no different then using a charger...it still uses the USB cable.
Here are a few things to check...
do not try a USB port that is off your keyborad or anything that does not come straight off of the motherboard...the phone pulls too much power and it will not work...
Try a different USB cable... some will not allow charging but will still tranfer data...
Also check and see if it asks you to install drivers for your phone...if it does, you will need to have them installed to charge the phone...
My best guess is that you need a different cable...
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse.
If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows.
If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
I have for my phone a program that i got when i bought it. Without this program i cant even open it so if you have a program that came with your Motorola then install it if you dont have anything then check if your Usb port is working ok...try to connect it to a nother USB port
Yes you can load a discs into it but only the softwares for it or drivers to be exact, how ever there are application that will allow you to install a program to your USB drives. try portable apps, search for it on google so you'll know the details and compatible programs for it
not sure what you mean by "pull up anything"
USB is a connection type - a means of connecting a device to your computer (e.g. digital camera, printer, flash drive, etc.)
what are you trying to do?
