There is very little that can be done, salt water will corrode metal on contact, all eletronic parts have been compromised, if the memory card is still intact save your pictures and remove it from the camera to transfer to new hardware. Replacing the camera unfortuneately is the only option.
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
SOURCE: can't upload video from camera to pc Olympus TOUGH TG-310 Digital Camera
Do you have Windows Live Photo Gallery? It comes with Windows 7, but if not you can download it here: http://windows.microsoft.com/en-US/windows-live/photo-gallery-get-started
You can also try and select the videos you want using the file download module Windows displays when a new device is plugged in. If that doesn't work, try
I have had video issues with my Olympus TOUGH (could not delete them from the camera) which turned out to be a formatting problem with the memory card.
