HP Color LaserJet 2600n Printer Logo
Posted on Apr 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Four small black ink smudges (1/32" wide x 1/16" high) are in right margin of all documents printed. Starting in upper right corner of page, 1/8" inboard from right edge of paper, they are spaced vertically down the page as follows:
Smudge #1 - 1" down Right Margin (RM)
Smudge #2 - 3" down from #1
Smudge #3 - 3" down from #2
Smudge #4 - 3" down from #3 and 1" up from b/o RM and page. Smudges look to be generated by round object, given their 3" equal distant increments. If so, ink/debis is on a wheel, gear, or cylinder that has a Circumference of +/- 3" and a Dia. of +/- .955".
Also, per Owner's Manual - Maintenance Toolbox instructions - performed 'Clean Printer' function twice, but smudges still present.
Thanks for the help.
Charley
Anonymous
Level 2:
Sniper:
  • Expert 121 Answers
  • Posted on Apr 07, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
121
Questions
0
Helped
87114
Points
411
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Ink smudge on right side of paper
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
Lexmark printer is printing pages out with three black smudges on left margins
Best bet is to remove the cartriges, open all areas of the printer you can, remove the fuser. Then take a can of air and blow everything out. Reasemble the printer and run a few test pages. The smudges may be worse at first but should clear up. If this does not work, then try replacing the cartridges with a spare if you have one. If you find that it is a certain cartridge that is causing the issue, then you have a bad one. If it makes no difference at all, try to replace the fuser.
Black ink on right margin when printing
it can either be the imagine drum or the toner. If there are scratches or smudges on the imaging drum it can cause that problem, or if toner is escaping out of the toner cartridge. try removing both, I believe they come out in one piece and inspect.
Hp laserjet 3380
The problem is not your scanner, is in the rollers, the rollers are smudged with ink or other mateial or your glass is smudge, remove the four star bolts on the top and clean the undersurface of the glas with a conventional glass cleaner wipe and re install the top cover.Be careful with the ribbon cables connected to the circuit board.
Printing vertical grayish black ink on the left and right side of page
replace the toner cartridge, you wont have anything "dripping" out of it as the toner inside is a powder. if it still appears replace the fuser.
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
1helpful
2answers
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
k24674
Grand Canyon Tech
Grand Canyon Tech
