Question about Sansui 32" TV
Circuit diagram only Red Light is coming.. after that not getting switched on both by button and remote.. Please guide me for repair,, i didnt know LCD repair..
    Top Expert:
  • Sansui Master
  • 54,386 Answers
The red light indicates only that house power is getting to your TV. It is likely that the internal power supply has failed
Posted on Aug 17, 2013
6ya staff
SOURCE:
Although the red light for the TV is on and flicks when I press a chanel number on the remote, nothing happens-I have changed batteries in the remote. Any suggestions? TV is TX-L42E3B
At www.reliable-store.com get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
Mar 13, 2018 | Televison & Video
How to fix headlights they wont come on at all and the switch/button wont light up as light indicator
Sorry Shannon but this is something best left to an automotive electrical repair shop. This is very complex with lighting control module controlling the lights . But if you want to try ,I suggest you go to youtube an check out some videos on basic electrical trouble shooting , how to read wiring diagrams , voltage drop testing . Then buy a DVOM - digital volt ohm meter . Go to http://bbbind.com/free_tsb.html , You can get free wiring diagrams there.
Feb 08, 2016 | 1991 Buick Park Avenue
Bought Walker tv and remote stopped working even though the red light comes on once i press any button... please help
Check the remote control for its infrared emission. The red light on the remote you see is not the infrared light, but an indication only, that there power comes to its circuit, as you press a button. The infrared LED is placed at the front end of the remote control. If you wish to get more details about how to check a remote control, try this link. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 16, 2013 | Televison & Video
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
When I switch tv on at button on tv I van hear the tv goes on. No Picture. If I press buttonds on the remote I can see the red light come on that indicate the remote is sending signal. Here comes the best...
Replace , front panel switches , one or more switches goes high resistance
when suppose to be open circuit , my sv2918 74cm was doing weird things
with these switches going bad
May 10, 2011 | Sansui D 27" TV275 TV
Hunter Ceiling Fan 25885 remote won't turn off light
I have this fan model. The RED is a common wire. Wire it in with all the white wires. Better yet why don't you just bypass the module for the light. You could buy a more up to date Lutron wall switch W/remote control. The Black wire W/White stripe coming from the module is the light control. Cut & cap this with a wire nut. The same wire coming from the fan motor Connect it to your new wall switch. Now heres the tricky part. You have to run a new (Non switched) hot wire to your fan this will connect to the module normally. This is the new power for the fan. The remote that comes with the fan can serve as the On/Off 1,2 & 3 speeds. You now have two remotes. One for the fan the original and one for the light control w/wall switch. The new Lutron model will give you full dimming capability for incondesent bulbs. It is much less noisy when you are dimming the light down.
Jul 24, 2009 | Hunter 28486 Ceiling Fan
I need a wiring diagram for a 1985 ford f250 pick 4x4 truck and I cant find one online.
ok carmona, go to autozone website, enter your f-250 info, click on vehicle repair guide, then chasis electrical, then wiring diagram. Let me know if u have any trouble accessing the info. Good luck!
Dec 07, 2008 | Ford F-250 Cars & Trucks
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Sony trinitron KV G21S2(i think)
Id you have no TV repair experience, play it safe and take the set into an authorized Sony repair place to estimate the cost to repair. Yes I know it would be nice to repair, but how much do you know about component level printed circuit board repair? You will need to first get a service manual, know how to read a circuit diagram, thats a schematic, and know how every circuit works with each other to make the TV set operate. I do appriciate the fact you would like to repair this yourself, but there is no magic fix in most cases when it comes to electronics. There is circuit diagnosise involved. Best advice would be to call in a pro to assist you in these types of repairs. Good Luck
Jun 23, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sansui 32" TV Logo
76 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
