Anonymous Posted on Aug 17, 2013
Vivitek qumi q2 cant find sources - Office Equipment & Supplies
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
1885
Points
28
Vivitek Qumi Q5-RD turns off after a few seconds.
IS THIS A COMPUTER?
No it is a
Vivitek Qumi Q5-RD review A portable but robust projector did you read the manual on this projector, No 2 projectors made work the same nor diagnose same or same error codes
thus the magic manual for that topic.
we use google to find manuals using clear english questions.
like
Vivitek Qumi Q5-RD manual. first hit google finds it, amazing no?
and is 7 years old now, 2013
page 48 is the only error pages..
blink codes. temp lamp blue binks is overhtemp]
did you clean the projector this old first all lint in all vents and inside, every drop of lint blown out? this is 1st on all things made that get hot. Computers and that. thing .
q5 series.
https://www.manualslib.com/manual/1140891/Qumi-Q5.html?page=48&term=error&selected=1
are not free manuals , not amazing, ?
or get the thing serviced in shop, not get electrocuted or burned.
respect both and win.
Projector auto shut down
The blink pattern indicates the LED emitter is overheating.
I have a vivitek qumi q2. It runs for about one minute and the turns off followed by a series of blinking lights on top, 3 blinks, pause, two blinks. It is getting warm so I think it may be a fan problem,...
The blink pattern does indicate that it is overheating. You can find the user manual for this device via a google search. The troubleshoot codes are on page 37.
I have a vivitek qumi q2 that runs for about a
The blink code indicates overheating. I suggest cleaning it.
How can I stop my Qumi Q5 shutting down after a minute?
It is most probably overheating. First you need to open up the unit and see if the fan moter is frozen. It is probably because you can't hear it spinning. There are usually two bushings one in the front and one at the rear of the motor. They are usually permentally lubricated but as we know nothing is forever. So, try to take some good quality oil like 3 in 1 and try to drip a drop on either side of the motor where the shaft comes out and then try spinning it by hand. Hopefully that may work but if not then as a last resort try spraying just a very small amount of WD-40 and try spinning it again. If it then does work then use the 3 in 1 again. WD-40 will probably clean the gum out of those bushings but it is not a proper lubricant so that is why you need to use that 3 in one or any good quality lubricant like gun oil.
If all else fails then you probably have a bad fan motor and it will have to be replaced. Just so you know I have had this same problem, usually with air conditioning fan motors and most of the time the lubrication method that I just described worked very well.
Good luck,
Marty
3answers
Vivitek Qumi Q2 reset ?
Unplug the power cord from projector
--> HOLD down (keep holding down) the right key on the keypad (top of the projector) and Insert the power cord back to the projector
--> The "Power" and "Ready" LED light should blink TWICE and unplug the cord from the projector (while still holding down the right key)
from facebook site
Hi--my new Vivitek D5 projector is not connecting to my Macbook. I have a mini DVI converter attached to a vga to DVI video adapter, but the projector can't "find" the source.
Please check your port with another source to confirm the working of the PC. Now also try to see if the projector connects with another PC. This will confirm the culprit as it is possible that there is a signal mismatch to the source input and hence not detected.
2answers
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
1helpful
4answers
Direct tv recorder and Vivitek V37835 46 in. LCD remote code for controller
IN THE GOOGLE SEARCH ENGINE TYPE VIVITEK V37835 MANUAL. ONCE YOU GET THE MANUAL LOOK IN THE SECTION OF THE MANUAL THAT SAYS SETUP CODES FOR SATTELITE RECEIVERS. FOLLOW THE INSTRUCTIONS FOR PROGRAMMING UR REMOTE. ALSO WANT TO LET YOU KNOW THAT I HAVE DISH SATTELITE AND I USE MY VIVITEK REMOTE NOT THE SATTELITE REMOTE FOR MY PROGRAMMING. MAYBE TRY THIS. IT WORKS FOR ME.
k24674
ADMIN Andrew
ADMIN Andrew
