Question about Music
My roland xp-50 keyboard is dead.
I have 110V to the transformer but the display is blank. I don't know what the output voltage is supossed to be, and I don't see any fuses or damaged circuitry.
  • 7 more comments
  • Anonymous Apr 19, 2009
    hey mine is the same way too, I just started looking
  • Anonymous Apr 22, 2009
    Same for me---power on, but LCD is blank and all functions and sounds are gone.
    Jet
  • Anonymous Apr 24, 2009
    the same happened on mine a few days ago
    any solution, please post
  • TURMIXXX Apr 24, 2009
    happened the same on mine a few days ago
    im not sure, but i think it could be caused by a power supply failure.
    any solution, please post. i will also be pleased to discuss it.
    turmixxx@hotmail.com
  • Anonymous Apr 28, 2009
    My tech here (in Hong Kong) reports mine cannot be repaired as it's a motherboard problem and these are now out of stock. I'm heartbroken.
  • Anonymous May 05, 2009
    I can't believe we all have had the problem all at the same time!!! My screen just stopped working. It still glows orange, but there is no black writing. I have a Roland XP 50. The lights on some of the buttons work intermittently. I am wondering if there is dust on the mother board or something? I wondered if it was a screen contrast setting because my child was playing with it moments before it happened. Any solutions? merridyandrew@hotmail.com
  • Anonymous May 10, 2009
    Same problem with my XP-50.
    I'm searching for a pdf free service manual for it.
    Also searching for an used mainboard for it because the problem is there.
    best regards.
    José.
    Portugal
  • John Robinson Jun 10, 2013
    I get display on LCD no problem but sadly no sound at all
  • Balaji Sridharan Jul 22, 2013
    Call 9500013495 service engg chennnai
  • 5 Answers
Ok guys. Just got mine XP50 fixed with the "No Display" problem. The LCD screen was blank without text and only shown orange color. The problem is one of the capacitors on the main board was dead. I have replaced all 3 caps on the main board and the problem is solved and if you are a little handy on soldering, you can do it yourself. The 3 caps you should replace are:
- C901 (I used 16V 330MicroF)
- C65 (I used 5V 4.7 MicroF)
- C 902 (I used 16V 330 MicroF)
Posted on Mar 07, 2010
  • 1 more comment
  • MattLen Aug 31, 2010
    In my case just changing the CR2032 buffer battery did the job. After switching on after that the display was still hardly readable, so I went through the reset-procedure as described in the Roland XP-50 TurboStart sheet (or the manual). After that everything worked fine again.
    Here is the procedure in case you don't have it:
    1.) Press UTILITY
    2.) Press 4: SOUND on he 10-key pad
    3.) Press 5: PRESET
    4.) Press ENTER
    5.) If Memory Protect is on, press DEC, then ENTER twice
    That's it - good luck,
    Matthias
  • stagerhodes May 03, 2011
    those caps your refer to solve the XP-50 blank display problem, are they Electrolytic ? or any other type ? i'm about to try this solution since my XP50 is exacltly with that blank screen problem..cheers
Turns out this is a design fault with the XP-50 model. My techie says he sees it all the time in this model. The XP-60s and XP-80s are designed differently, he says, and never suffer from this fault. His tip: if you have a unit in working condition, have the capacitors replaced. So, unless you can find a new (i.e.unused) mother board, a second-hand replacement is perhaps just a temporary fix. I've sourced a working second-hand unit and my techie is going to do the modifications required to ensure the "lights out" fault doesn't hit me again. Grim news, but that seems to be the case, and that so many of us have listed the exact same fault, seems to confirm it.
Posted on Jun 16, 2009
    New Friend:
Hola,soy de republica dominicana,soy tecnico de teclados roland y korg,he tenido mucho este probleam en mi taller y me he dado cuenta de que la humedad tiene mucho que ver,los xp50 se construyeron con poca proteccion en la tarjeta madre y les puedo ayudar a solucionar el problema en definitivo,audiosou@hotmail.com,no me molesta conpartir mis experiencias en la electronica.
Posted on Nov 15, 2010
    New Friend:
  • 8 Answers
I have the same problem but in additioni have a strong noise in the left channel which stops after 4 or 5 minutes...
Posted on Aug 11, 2010
  • Theo Ntizas Aug 12, 2010
    i found another solution for the no screen problem..!
    Just remove the wire that is on pin # 3 of CN14 and solder this wire to the ground of PCB mainboard!
    This will lock the screen contrast to a standard level and you cant change it even from the menu...
    Hope this helps..!
  • wizzibizzi Jun 28, 2011
    This is the solution for my XP50! Thank you for that hint! Unfortunately i've change all the capacitors and the CR2032 before trying this... but only your hint (removing pin #3 from CN14 and connect to pcb mainboard ground) does it... i'm happy, my XP50 is alive! :)
    Problem Solver:
  • 8 Answers
Plug it in!
Posted on Apr 07, 2009
    New Friend:
Just encountered the blank display problem on my XP50.
Changed the CR2032 buffer battery and went through the initialization procedure as decribed on the Roland TurboStart-sheet. http://cms.rolandus.com/assets/media/pdf/XP50ts.pdf
Hope this helps!
Posted on Aug 31, 2010
    New Friend:
  • 3 Answers
Dear, you can get one here
http://servicerepairmanuals.net/others/roland/roland-xp-50-music-workstation-service-manual-notes/
Posted on May 20, 2012
    New Friend:
I have a roland jv50 with no diplay problem too are the capacitors in the main board still the problem too?? could u help me guys
Posted on Apr 25, 2010
6ya staff
SOURCE:
Repair for vintage keyboards.
Static is usually the result of a bad connection. I suspect there is a bad solder joint. If you are electronically inclined, use a listening device or oscilloscope and connect it to the volume control terminals if it is not present on the input to the volume control then it is the volume control that is bad which happens in old equipment best solution is replacing the volume control or you can try cleaning it with an aerosol product for this purpose.
Sep 05, 2018 | Roland Music
How to replace roland xp 50 keys And also repair outputs
Disassembly the unit.
Your question is less detailed. If the keys is broken,replace with new.
If you mean "How to",then you need the service manual.
Outputs problem,usually causes by output IC (or input IC) is defects.
It also can cause by AD/DA IC is error.
Mar 15, 2015 | Roland Music
No sound from my xp-50 keyboard. I replaced the battery, screen is lit, but no sound
Make sure there is not a switch that makes it output to external speakers.
Apr 09, 2014 | Roland Music
MY ROLAND XP-50 HAS NO SOUND WHEN I PRESS THE KEYBOARD
how to hook up roland dm 20 to...computer.
Feb 28, 2013 | Music
I have a roland xp-50 with no power at all. What should I try?
ftp://ftp.roland.co.uk/productsupport/
I would start by checking AC cord is good, look for a blown fuse (BE CAREFUL !!!!) or maybe a defective OFF/ON switch. This keyboard is from the mid 1990's so PLEASE consider this before having it expertly repaired. $$$$$$$
Oct 31, 2012 | Roland Music
Hi, My Roland Fantom G6 keyboard has an accident and the analog output is dead. I ask you if it is a possibility to find the entire Jack Board for replacement. It is named: FANTOM-G6 JACK BOARD ASSY...
Does the headphone jack work? Replacing a whole board would be expensive and the problem could be elsewhere. What was the accident? If large signals were driven back into the audio out lines, probably the output driver chip is fried... They likely use a common 8 pin dual op amp as the driver and the part costs 50 cents. It takes a little care to replace it as it is likely surface mounted. I am looking at the audio/jack board for a G-600 and there are a pair of transistors for some testing they do that could also be fried and might be the whole problem if the G-6 uses same or similar circuitry. The Fantom X6 uses very similar circuitry... Download service manual here:
http://elektrotanya.com/roland_fantom-x6.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links. On page 57 of 66 you will find the audio drivers at the right. They use little dual op amps M5218APF which probably are available someplace, however probably 4568's would work fine and are readily available. If you drove high voltage into the audio outs, I suspect first that the RF bypass caps such as C203 on the above schematic shorted. Simple to replace... pennies apiece... The test path transistors such as Q37 may also be shorted... Next would be IC18... While this circuit may not be the exact one for the G6 it probably is CLOSE as the several Rolands all seem to use similar circuitry. Regarding system SAFETY... Make sure ALL and I do mean ALL equipment interconnected including mixers, powered speakers, keyboards, etc. are powered from the SAME receptacle or power conditioning module to avoid accidents. Also for keyboards sent to mixers, USE DI boxes please! These protect against ground loops and these accidents.
Sep 13, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
I have a Roland AC60 amplifier that I brought from Australia to the US. The Australian version of this amp runs on 240 volts not 110. My question is; 1) does anyone know if converting this amp to...
The only simple way that I could think of is for you to purchase a STEP DOWN TRANSFORMER rated at 500 watt, 110 volts, 60cycle. The transformer inside that amplifier have four output 12v and 15v DC.2amps It will be hard to get the transformer for that! Hope that might help you! taah!
Nov 18, 2010 | Roland Ac60 Acoustic Chorus Guitar...
My Roland d-50 keyboard ic
There are lots of IC's in the unit. Order from Roland support parts. That will be the only source.
Jun 01, 2010 | Roland Juno-D
Roland XP 50 Head phone not working
Make sure that the level of the headphone out put is open. Make sure it is on manual adjustment and no auto level. And test your headphone on a other device to clear that your headphone is not broken. If all these options are correct you headphone pre amp of the XP 50 may be damaged or broken.
Mar 07, 2010 | Music
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Music Logo
9,199 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
