The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
Unplug washer or disconnect power for one minute.
Plug in washer or reconnect power.
Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Yeah - seems like it. My pile of laundy is getting bigger.
Thanks for your quick reply! :)
Sounds like a DOA(dead on arrival). I would attempt to use the warranty immediately if possible. you may have a lemon.
did you remove the transit rods?
error code f23
