The
1394 bus driver was rewritten for Windows 7 to provide support for
higher speeds and alternative media, as defined in the IEEE-1394b
specification. The 1394 bus driver that is included with Windows 7
replaces the 1394 bus drivers that were included with earlier versions
of Windows.
For more information, please refer to this document: 1394 Bus Driver in Windows 7
In addition, according to Windows 7 Compatibility Center, JVC Americas GR-D350 High-Band Digital Video Camcorder is compatible with Windows 7 x32 bit.
You can refer to the instructions in this website and see if the issue can be resolved: Windows 7 1394 Firewire devices not working?
Hope this helps.
SOURCE: Drivers,,controladores...
Drivers are already preloaded for your camcorder as long as you are using Windows XP or Vista. You will need a program to capture the video to your computer. Pinnacle Studio will work for your camcorder.
Once the firewire cable is installed and the camcorder is turned on, pinnacle studio will give you the option to load itself up.
Seg?n Windows 7 Centro de la Compatibilidad, impresora de Oki B4350 es compatible con Windows 7 versi?n x64. Si el asunto persiste, puede intentar de instalar al conductor de la Actualizaci?n de Windows para hacer clic aqu? :
http://catalog.update.microsoft.com/v7/site/Install.aspx?q=Oki B4350&referringpage=Search.aspx
Tambi?n, es recomendado contactando Oki para verificar directamente este asunto.
Adem?s, va por favor al Tablero de control -> Dispositivos e Impresoras -> el derecho hace clic en la impresora y entonces clic Localiza fallas para ver si el asunto puede ser resuelto.
Buenas Suerte,
Jose Diaz
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
