Whirlpool LER6636PW Electric Dryer Logo
A
Anonymous Posted on Aug 17, 2013
Hot and damp air does not exit the dryer - Whirlpool LER6636PW Electric Dryer
1 Related Answer
Anonymous
  • 331 Answers
  • Posted on Aug 21, 2007
SOURCE: Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
1helpful
My hot point tdl30 dryer, doesn't heat up like it used to, meaning I have to run it for longer!! Any help greatly appreciated
Getting your clothes dryer to work efficiently means hot air and air movement! Check your dryer vent hose. It may be clogged or even plugged. If that is the case then all that damp air isn't getting exhausted.
Jan 02, 2015 • Dryers
Bravo steam dryer getting hot but clothes are still damp
Hello Shawn.
Glad to see you got it sorted out.
Maybe you place a "how to.." tip for a wider audience.
PS- while reading your added comment / update re the fix, the 'comment' block suddenly vanished as I exited from it!
Not sure what happened there.. ;[
Maybe try retyping it?
Regards,
Clive.
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your cloths are "hot and damp" you are not getting proper ventilation. Since you cleaned the vent trap let's try a few things to narrow down where this vent restriction is coming from.
  1. Let's pull that vent trap up and start the dryer. Place your hand a few inches in there. Can you feel a light suction of air? (flowing into the dryer)? We will get back to this shortly. Next -
  2. Take the vent hose off the back and turn the dryer on? At this time you should get lots of warm air blowing. If you do not have this and the vent trap did not have any noticeable air flow (into the dryer) then thus far you have a clog between the vent trap and the vent in the back of the dryer. Unplug the dryer and from the rear of the dryer remove the back panel. Should be just a few 5/16 nut with a possible flathead screwdriver indention on them. If you have to do this let's still check the pathway for ventilation to the outside and make sure one did not trigger the other. And if all ventilation to this point is good then -
  3. You have a clogged vent restriction between the duck and the path it takes to outside. For this a duct cleaning service will have to come out and take a high pressured air hose and blow that pathway clear. Now if you have a fairly high powered compressor and can locate the exit for the dryer vent then -
  4. Charge that compressor and put an air gun adapter on it and (wearing eye protection) blow the heck out of it. This will make a huge mess no matter who does it. Make sure it is a good size shop compressor and not one many people carry in their trunk for inflating flat tires (this one will not work) This is how the duct service will do it also.
Mar 20, 2011 • Dryers
The dryer is hot but the cloths are damp after 2 hours in the dryer..its hot but the cloths are still damp?
check the air in let and out let pipe are not blocked up with fluff if the dryer cant breath there will be little hot air going through the cloths to dry them out,,,also check the "dust filters"
2answers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 • Dryers
3answers
The dryer does get hot but takes a very long time to dry a normal load of clothes. What I noticed is that the top right hand corner of the dryer gets scalding hot during the cycle. It worked fine before I...
It sound like you have a venting problem. The air from the dryer is probably restricted by either a clogged exhaust hose or duct work in house or a stuck vent flap where air blows to the outside. If your vent goes straight up to the roof, something may be blocking the exit or the whole line may be clogged. Also check for a kinked flex hose that attaches to the dryer. If blockage is in wall of house, there are vent cleaning companies that can clean out the line.
Clothes still damp
have you checked the dryer vent,wall vent lint trap for cloggs,if clogged it will hold the damp hot air in the dryer much longer and add to your drying time-mike
May 29, 2009 • Dryers
After 40 minutes of drying clothes are still damp... there is some heat
you need to check the wall vent hole to make sure it's not clogged,check the dryer vent hole to,most of the time a dryer does not dryer good because the clogg is holding in the hot damp air-mike
Feb 23, 2009 • Dryers
I have a whirlpool dryer that heats until I walk away and when I come back it is blowing cold air and my clothes are cold and damp. I blew out the dryer itself , dislodging much lint, removed the back and...
It sounds like you have a clog in your vent line somewhere between the point where it exits the dryer to where it exits the house. You may still need to remove the entire line and clean it thoroughly.
Here's an easy idea you can try to determine: Remove the vent hose from the back of the dryer and try running a load with the hose removed. The air leaving the dryer should be hot (about 140 degrees F) and forceful. If it's not, you have a clog INSIDE the dryer somewhere. If the air flow is normal, allow the dryer to run to see if your drying results are better. If so, you have venting problems EXTERIOR to the dryer. Either your vent line is clogged, is kinked somewhere, or too long. Remember: The SHORTER and STRAIGHTER a vent line, the better. If your drying results are about the same, then you probably have an operating thermostat that failing. Here's a helpful link you can try to assist you in troubleshooting:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Let me know if your need further assistance. I hope this helps you.
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
