Procedure for reset this firstly enter in service mode.
Procedure[ press yellow all clear button>press107>press clear/stop button hold until 4 second. you enter in service mode. than machine off and on.
If your problem is not solve so firstly enter in service mode. than press 1 > select [mode] with up down arrow key> than select [memory all clear] with up down arrow key> press [execute] press OK than machine off and on. or some cases replace thrmister.
SOURCE: error code SC542, unable to clear message from
this is an error for the fuser heat up..the temp is not being maintained or fluctuations. try this press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.turn machine off.. if the code disappears it could have been just a glitch if not check the fuser to see if there is heat coming from it the lamps will come on at te start up. you can check this by putting a screw driver in the actuator slot to cheat the door switch if you see the lamp come on then you may just have to clean off the thermistors .. open the fuser up with the top screws and check that there isnt any build up of toner on thermistors..hope this helps good luck A
