Hello, my name is Steve. And you are half-way there.
Next you need to go to Canon's website and in Driver and Support, get the latest drivers for your Canon. printer.
Your present software does not have these new updates. this is why you are getting this error code for your scanning support. It is not yet compatible with your new platform.
When you installed the canon drivers did you install MP Navigator? That's the program you use with the MX452 that runs the scanner. Its on the disk that comes with the printer.
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
If you dial the mx452 does it indicate it is ringing. If not it does not see the phone line, if it does
try to fax to a phone you can here, does it ring? no need to answer. If not you you have a dialling out issues
