"playback feature may not be available on this disc" I burned a movie from my computer and each time I try to play it on my dvd player I get the message disc error playback feature may not be available on this disc. Help please Thank You.
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
http://www.nero.com/enu/downloads-nero9-trial.php
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Usually it's because the movie was a PAL (European) format and you didn't burn it as an NTSC (American). You need a video conversion program, where you can select NTSC when you run the conversion. The resulting VOB files can now be burned into a DVD.
SOURCE: disc error "playback feature may not be available on this disc"
the message you are getting is the machines waay of telling you that it can not read that disc. which means you will have to burn your discs in a different format. or your are using a type of disc it does not recognize.
tom
my dvd player is giving me the same message no matter what dvd i have in it. it won't even play disney movies
