Need to change the battery on a Timex Men's Digital Expedition Chrono Alarm Timer Watch
Hi
please follow the steps to change the battery
thank you....
HI...
the following are the simple steps for replacing the battery
Step 1
Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
Step 2
Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
Step 3
Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
Step 4
Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
Step 5
Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
THANK YOU...
