Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire Side-by-side not cooling or freezing
Fan is making a strange noise (on & off), louder than normal, more metallic buzzing sound. Refrigerator compartment blowing very light air, not feeling anything in freezer. Everything in freezer has defrosted.
  • 190 Answers
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Posted on Apr 08, 2009
  • Ajith Kumar Apr 08, 2009
    u can click on the links to get the "do it yourself" instructions for checking.
6ya staff
SOURCE:
Frigidaire freezer making humming noise name brand frigidaire
if it is like a buzzing sound and it is a two door unit, and you can tell from which side the noise comes from, either from the fridge or freezer side please do so-
Also, has it begun to take longer to cool ? if so, you may have a worn out evaporator fan that sometime in the near future will be ruined and the fridge will not cool as needed
If that is so, the replacement part runs somewhere between 35.00 to 50.00 plus the technician labor cost to replace it
Aug 19, 2014 | Refrigerators
Buzzing noise
If it behind the ice maker more than likely its the evaporator fan that is making the noise.
Oct 19, 2013 | Frigidaire FRS26H5AS Side by Side...
Frigidare freezer making buzzing sound like a motor
You hear the evaporator fan that is probably rubbing on some ice buildup. Remove the rear panel in the freezer to confirm that there is ice buildup and post back to me.
Nov 17, 2012 | Frigidaire FRS23KF7AB Side by Side...
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
MY HOTPOINT HAS A SIMULAR PROBLEM......IT SOUNDS LIKE YOUR CIRCUIT BOARD IS BROKEN...THERE ARE NOT THAT MANT PARTS TO A FRIDGE/FREEZER SO THE LIKELY HOOD IS CIRCUIT BOARD OR MOTOR.....HOPE THIS HELPS
Dec 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
449 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
