Question about Ricoh Aficio BP20 Laser Printer
Online error hi my printer is saying online/error on actual printer what do I need to do to change from red to greeen. Thanks
Hi, I have re-filled the black toner cartridge, but the display says it is still empty. The red light is on and it won't print. Any suggestions please? Many thanks.
you need to use the menu on the printer and find the selection that says printer options-> ink cartridge-> new ink cartridge. what happened is you never told you printer that you were installing a new cartridge so it thinks that its still the old one. The printer actually never checks cartridge levels it just makes predictions based on how many pages you have printed.
Jun 30, 2011 | Samsung CLP 300 Laser Printer
My printer say ctd sensor error 009-340 how make resolve this problem?
Hi. Easy! Open the front cover and you will see two stickers with red borders in front of you. About 10mm above them is the sensor - dust it with a cotton bud or tissue.
Simples!
Jun 20, 2010 | Dell 2135cn All-In-One Laser Printer
We have changed the filter, but the red light saying that it needs changing is still on. How do you get the red light off? thanks.
Check you manual for a reset procedure; they often require a button sequence to reset error modes. The sensor or timer knows when to change the filter but doesn't know if it was actually done.
May 24, 2010 | Amana ARS2464B Side by Side Refrigerator
I have a HP Deskjet 5440 that I replaced the tri-colour cartridge on and the thing just stopped working. Currently the power light is on and the down arrow button sometimes appears flashing in amber (never...
Unplug the power and replug it .
Make sure you removed the protection tape from the cartridge.
Try pressing the down arrow button and see if the error goes away.
In vista right click the printer and select the option Use printer online.
If you need anymore help please let us know.
Rate the answer if it helped.
Thanks
Sep 21, 2009 | HP Deskjet 5440 InkJet Photo Printer
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
I850 printer error message 5100
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Jun 19, 2008 | Canon i850 InkJet Photo Printer
Canon ip 1000 inkjet printer
check out this link http://www.fixyourownprinter.com/forums/inkjet/16073
Aug 26, 2007 | Epson Stylus Photo® R2400 InkJet Printer
Ricoh Aficio BP20 Laser Printer Logo
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
