Microsoft Windows Vista Ultimate Edition Logo
A
Anonymous Posted on Mar 25, 2017
Windows Live mail unable to open message store First message: Windows Live Mail could not be started. The application was unable to open the Windows Live Mail message store. Windows Live Mail was unable to locate its message database. If you've moved the database files to a new location, click OK to reset the database path to that location. Otherwise, click Cancel to proceed, any existing messages found will be available under Orphaned Accounts. (0x00000000) Click ok then get.... Second Message: Windows live Mail could not be started. The application was unable to open the Windows Live Mail Message store. Your computer may be out of memory or your disk is full. (0x800700002) Click ok program closes.
5 Related Answers
Anonymous
  • 44 Answers
  • Posted on Aug 21, 2008
SOURCE: registry editor not opening need help
Go to command prompt and type Sfc/scannow.You may need your xp installation disc since this command tries to verify your windows installation by comparing the files to the one on the cd.Also this might be due to a virus,go to this link and use this tool to scan your computer.The tool can let you know if you have a virus or not.
Anonymous
  • 449 Answers
  • Posted on Aug 08, 2009
SOURCE: 0x71ab664d reference
explorer. exe is a virus or spyware. install any spy ware remover you know on your system and scan the system to remove the malicious ware
Anonymous
  • Posted on Sep 19, 2009
SOURCE: Explorer.exe Application error in Windows XP Professional SP2
i think you must to format it with the good cd windows because the problem is has an error while installing windows. thx
Anonymous
  • 80 Answers
  • Posted on Nov 09, 2009
SOURCE: 0x71ab664d" referenced memory at "0x71ab664d".
increase its virtual memory
Anonymous
  • 1082 Answers
  • Posted on Sep 11, 2010
SOURCE: When i open some applications windows shows the
These error messages may be caused by the WORM_KLEZ.E virus, or one of its variations.
Go to trendmicro.com and run their free online virus scan. It can take a couple of hours to run and you must be connected to the internet.
It that doesn't do it let me know.
When live mail opens there is a box which says sorry, something unexpected happened and windows live mail must close. Your recent changes may be lost. emails will not load. how can i fix this?
If you are using windows 10, live mail wont work, go to the play store and get mail. If you are mistaken and have mail and not live mail, the process to remove and reinstall is very involved. Let me know
Can not add Window Live Program to NP Navogator program
MP Navigator EX Failed to send e-mail. Check your mail program ...
answers.microsoft.com/.../windowslive/.../livemail.../mp-navigator.../8a2...
Nov 4, 2015 - Unable to send a scanned page by e-mail. ... But adding Windows LiveMail to MP Navigator EX's list of Mail Programs via wlmail.exe (One-click [button]->Attach ... Can not run Canon MP Navigator on Vista Home Premium (32 bit ...
Nov 11, 2015
Windows Live Mail properties won't open.
Oct 17, 2015
MAPI
Oct 17, 2012
More results from answers.microsoft.com
Canoscan MP Navigator EX 2 Windows 7
www.blizzardcomputers.com/canoscan-mp-navigator-ex-2-windows-7/
Mar 21, 2013 - After you install Windows Live Mail from Live Essentials and set it as the default email program in Windows 7 you can't use the scan to email ...
1helpful
This is the message I get Please help me.
It's the same error as 0x800488eb about deltasync, follow steps here to fix it. How do fix 0x800488eb error on Windows Live Mail Appuals com
1helpful
I am running XP Home & have downloaded windows
This is nothing to do with the Pictures, this is to do with your outbound SMTP server settings, you will need to double check all details including server name, username, password and ports
1helpful
Getting the following message from windows live mail, any help appriciated Unable to send or receive messages for the email account. The connection to the server has failed. Server: 'mailin.manx.net'...
The most likely explanation is that your ISP (manx.net?) server is temporarily down. You can connect by webmail?
If it is manx net then you can try accessing your e-mails by logging in on here.
If you can access through web browser, but want to set up windows live mail click here.
Settings for manx.net - for Windows Mail but same will apply in Outlook.
Hope it helps.
3helpful
4answers
Email Customer Service Call 1-8O5-225-669O We are 24 Hour Available Call Now For Help
You simple CANNOT. Windows Mail no longer supports the HTTP servers used by Yahoo! and other web-based e-mail providers. Windows Mail does not permit the use a Web-based (HTTP) e-mail account on a computer that is running Windows Vista.
For an alternative, use Windows Live Mail instead of Windows Mail
loadTOCNode(3, 'resolution'); Windows Live Mail is an e-mail program that you install on your computer. Windows Live Mail stores messages on your computer. This means that you can access, read, and compose e-mail messages even when you are not connected to the Internet.
Windows Live Mail works with popular Web-based e-mail services such as Hotmail, AOL mail, Google mail, and Yahoo! mail. Windows Live Mail is built to automatically configure many popular e-mail services.
To install Windows Live Mail, visit http://download.live.com/wlmail
HP 4670 Scan to email: how to open Windows Live mail, not OE
Click the Show Menu button, and choose Options; if you see the traditional menus, go to Tools > Options. Both open the Options dialog: under the General tab, which should be selected by default, locate the bottom section, labeled "Default Messaging Program":
img1a2.jpgIf Windows Live Mail is not currently the default email program on Windows, the text next to the first button will read "This application is NOT the default Mail handler". Click the Make Default button, and it will be disabled (grayed out).
img1d.gif Confirming your change of default email clientThe text has now changed to "This application is the default Mail handler".This is a bit misleading, because Windows Live Mail will not becomeyour default email application until you actually have clicked the Ok or Apply button to confirm the change in configuration.
img36wlm.jpgSoclick Ok (no need to Apply first), and Windows Live Mail's optiondialog will close, integrating your new option choices. It is that easyto make Windows Live Mail your default email program. (If Windows LiveMail was already your default email client, nothing will happen.)
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
