Water leaks from bottom during spin drain cycle out bottom of washing machine not from hoses. this is coin op model seems fairly old (20 years? ) maybe [email protected]
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
leak out bottom
My machine has recently started to leak a small amount water from the bottom . I have checked the hoses and they seem fine. Also after finishing the final spin drying cycle when I rock the bowl there is a sloshing sound .Is this normal to have some residual water left in machine.
water is leaking from the washing machine not the drain
machine was in rinse cycle when noticed waterr coming out of machine at the front bottom edge. turned machine off and leak quit
coin operated top load wahser mat 14csaww does not complete
machine screams during entire spin cycle
maytag performa washer is leaking from the bottom and is noisy during the wash rinse and spin cycle
leaking water from bottom of machine when filling up
I have a Maytag PAV 3200 - it won't DRAIN. Was told to check the filters & the drainage?
Need to know where the filters are located (obviously one will need to remove the sides of the machine) & I assume that the drainage area, will be at the end of the drainage hose?
thanks
Maree
leaks during wash cycle at bottom of tub
would not drain or spin. I have manually drained it and cleaned out filter, although there was very little in it. Retried spin cycle. Now anti flooding alarm is on. Looked at back of machine - nothing much of notr (slight leak around outlet hose but all drains free). Please help - all school uniforms in there!
Water leaks from the bottom of the machine
Washer will spin but water does not drain out
water is draining slowly in every cycle...
No water coming in but will run on spin. Add water by hose into the tub and it runs. Replaced control timer with no difference. No hot or cold water coming in. Is it the level control switch or the temperature control switch? Washer probably used 20 times in last 2 years.
water appears to not go to the drain
at the end of the wash cycle, water is leaking from the bottom of the machine
water leaks out from hose area, hose does not have a hole in it.
