Help we need to empty waste toner on kyocera 1820 and can't find it.
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
It is in the drum unit. There is usually a plastic cover to peel off to empty it.
Is the drum unit the thing that you pull out from the front after you unlock the blue lock on the left? Thanks
