Does this have a reset button and where?
SOURCE: Sony CFD-S300 boombox would not run CDs
what i would suggest you to do is get a q-tip and a little bit of rubbing alcohol on the tip and gently clean the lens let it dry
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
SOURCE: CFD-S300 tape recorder system not functioning
The most common problem with these is slipping belts. While a relatively simple repair for an experienced shop, these are a little tricky to repair for the first time. The belts shouldn't cost more than $6 total (I think there are 3 in this unit).
Dan
SOURCE: A Sony CFD-S300 was given to me without the
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDS300&LOC=3
SOURCE: Lost the remote for the Sony CFD-S300. Is there a
You can find what you are looking for at http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=CFD-S300&uuid=12666237547590 Let me know if you need anymore help
hardrocko
Thanks for using FixYa
