My Gestetner DSm725 all-in-one copier keeps reporting a paper jam, but there is no paper jam! How can I fix this?
SOURCE: Gestetner CP6123 giving error E12
You should check the all paper sensor, there must be a pieces of paper in some sensor and make the sensor in wrong direction. You should remove all and off the power for a while and the start to use it.
SOURCE: Gestetner c7435 paper jam at fuser unit
It sounds as if the actuator is out of position or bad. In the fuser exit there should be a thin little black (usually) actuator that hangs down and the paper pushes/ lifts it off of the switch/ sensor as the paper passes. If this is pulled out of its holder or broken it will act like there is still paper jammed. The actuator looks like a little ' j ' and is pressed into its holder. If this is seated properly then the switch is probably bad and needs replaced. About resetting --- a paper jam is considered an 'A' code and does not need the machine to be ' service reset '.
Please let us know what you find out.
SOURCE: how can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
SOURCE: My Gestetner Dsc445 shows a continuous misfeed
Verify the exit sensor actuator and the entrance sensor actuator.
Testimonial: "Ive just received the service manual, will check the actuators. Thanks."
SOURCE: Gestetner 2822 error code e-5
i got a strait black thin line on left marging of paper. i think margin setting of my Gestetner 2822 has been changed. but i don't know how to fix this problem. (107-C, ???)
