The spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
It's threaded and you use a stem removal tool to remove the old one. Make sure before installing the new stem, that you replace the seat in the manifold or faucet housing.
The problem I have is that there are no instructions for instllation for the Danco 9S-H/C stem 17469B . There are springs and washers and I don't know what order they go in or what direction.
How do i install a danco diverter stem?
