You'll need to calibrate your screen and your printer - calibration is required for every set of paper and ink you use. It's quite a science and an art. I suggest you google "colour space" "printer calibration" "gamut" etc and read up on it. Alternatively you could spend a few hundred quid on a printer calibration tool, either the Colormunki or the Spyder print studio.
It still won't match perfectly, as the way color is created on a screen differs hugely for to how it is produced on paper.
Start with a properly calibrated screen first though (my money is on the Spyder elite screen calibrator and spyder print calibrator)
I'm a pro photographer and I print my own photos - full system calibration is the only way. www.yourhandinmine.co.uk
To achieve true life like colors, the primary colors need to be balanced to produce a perfect black and white picture. Turn the color level on the tv to 0 and tint to middle then look at the picture - does it have a reddish or other "coloration" to it? Then set the individual color levels (if your TV has these settings) of red, blue and green to balance out and get a true black and white picture. After that, bring the color level up slowly until the facial levels are natural - not over driven as seen in most store displays. You may need to use tint control slightly.....
One other way - There is a dvd from Disney called "Wow" that aids in getting your set to optimum display.
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the
color ink. Note: Leaving the color cartridge empty or dry isn't good
for the printer. It can lead to poor print quality if you want to print color
in the future.
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To
print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can
lead to poor print quality issues.
Have the photo printer run a test/alignment page. Make sure you are not running out of one color. Anytime the image runs heavy on one color typically means another color is empty or low and not blending properly.
You can also check the settings to see if it is printing in Draft/Normal/Best Mode. Depends on the settings and application used to control this. Best uses more ink and of course provides the best image. Photo quality paper if you want the best looking pictures. Printing on standard bond will cause some bleeding and saturate the paper. (Looks feels wet) This will give the image a slight blurring dull look. Depends on the quality of the paper used also. Hope this helps!
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
To use the Color Correction Wizard, go to the printer's Color properties page, select User-defined color correction , then click Start Color Correction Wizard button. The Color Correction Wizard helps the user perform the following steps:
Choose the sample picture to be used. This can be the document that's open in the current application, or one of several samples provided by Hewlett-Packard.
Choose the type of correction to be applied to the picture. The brightness, the contrast, or the color balance can be varied.
The Wizard prints the same picture ten times with different degrees of correction applied to it.
Look at the printout and decide which of the ten is preferred.
A combination of corrections of different kinds can be used. For example, when selecting a brightness correction, the Wizard can be instructed to give another set of ten prints from which to select the contrast, or the color balance.
When the final selection is made, the combination of corrections that have been chosen will be saved. This combination may be saved and used in future whenever selecting User-defined color correction .
I suspect that the color is fine in the screen, if that’s true I would check the “White Balance.” This control is use to compensate for different light sources. The electronics will respond different for sunny or cloudy days and for incandescent or fluorescent lamps. I suspect that it was taken out of AUTO mode. I find that AUTO works well for most people in most situations.
Select photo or movie mode press menu, select WB, select AUTO.
