Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers
Probable Cause
An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action
a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Probable Cause
Corrective Action
b) Inspect display cable; Replace cable if necessary. Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Probable Cause
Corrective Action
Probable Cause
Corrective Action
You should check your power supply for proper voltage output first. Check for at least 110v. The following video will show you how to use a multimeter.
Error CodeReasonSuggested Action
5
No Slack
Enter test mode and test switch, adjust switch, inspect display cable for cut or crimp
6
No Brake
Adjust slack switch or replace motor
Tectrix Climbmax Error Codes
Those are always marked on the bearing shield itself. Look for a number that looks like this: RS 6802 RS or 6104 R.... it will be a letter/3 or 4 digit number/ letter combination.
