Question about Dryers
Kenmore stackable washer dryer. Dryer buzzer is
Kenmore stackable washer dryer. Dryer buzzer is so loud that it is causing our house to crumble and settle more than it should (lol). In all honesty, it is actually causing physical pain in my chest everytime it sounds at the end of the dryer cycle. I want to disable the buzzer. Does anyone have any idea how to do this? The buzzer is part of the timer apparently. Thanks.
  • Anonymous May 11, 2009
    97962 kenmore washer/dryer has extremely loud buzzer that is not under the user's control.
    How can I dismantle it without damaging the dryer.
    Sears technical support claim it is not possible, but this answer is ridiculous. If it's possible
    to have it, it should be possible to remove it.
    If you are knowledgeable, I would appreciate your assistance.
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Posted on Aug 26, 2009
  • mike watson
    mike watson Dec 10, 2013
    silence now. thank you so much
  • Breia A
    Breia A Mar 20, 2014
    Amazing! Ah, peace at last. Thank you thank you!
    New Friend:
I just did this; Zard's solution was not quite the same as mine. After removing the control panel (will drop and hang once you pull down on the two spring loaded posts), I located a part that looked like this:
There were two black leads hooked to it. I simply disconnected them and taped the tips with electrical tape.
Voila. Annoying buzzer is gone (detached).
Posted on Mar 03, 2010
  • 686 Answers
POST THE DRYER MODEL PLEASE
Posted on Apr 10, 2009
    New Friend:
Yahoo,no more dryer buzzer.it only takes 20 min.
while your disconnecting buzzer,vacume out the fluff and dust
Posted on Dec 10, 2013
Anonymous
SOURCE:
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.84042500 stackable gas dryer. Started
It sounds as if the bearings in the dryer have gone bad. The same thing happened to my dryer.
Oct 22, 2009 | Kenmore Dryers
Trying to disable the dryer's loud buzzer
The wiring diagram is located in the slanted panel above the washer door
Jul 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Turn off buzzers
I had the same problem and the buzzer was one of the worst sounds ive heard. But, I found the buzzer and turned it off for good. Open the front panel and look for a small part in between the 2 main curcuit boxes.I have a Fridgidare stackable combo FLEB8200FSO. On mine this small part is number 144547100. Look for two black wires, one goes to H and the other to C. Disconnect both wires and no more buzzer!! Good Luck
Mar 29, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
I have a kenmore stackable washer and dryer and the dryer squeeks really loud it drives me crazy and makes it hard to do my clothes
depending on the age and the usage of the dryer, it could be the belt, or the bearing that the drum rotates on
Jan 14, 2009 | Dryers
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
4,926 people viewed this question
Top Dryers Experts
Marvin
Marvin
Mike
