Question about LG WM0642H Front Load
HOW DO I REVERSE THE DOOR ON LG FRONT LOAD WASHER
  • LG Master
  • 2,528 Answers
Sorry but it cannot be done, not built to do so
Posted on Apr 24, 2015
6ya staff
SOURCE:
Anonymous
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
Anonymous
  • 210 Answers
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
Anonymous
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: LG front load washer -- water leaks
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
Posted on Jun 25, 2009
drallim
  • 4088 Answers
SOURCE: LG WM1814CW Front Load Washer rubber seal on front
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Posted on Sep 28, 2009
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
I want to change my LG front load washer so i will open to the right
Sorry, but the door on the washers are not reversible, only the dryer doors are reversible. I'd suggest using a low profile telescopic style dryer vent to allow you to put the washer on the left side without worrying about the dryer vent location. You can get longer dryer power cords if needed, and water supply extention hoses, or just longer hoses if needed. The drain hose is usually long enough to still reach the drain. I have done this many times.
Sep 28, 2009 | General Electric WCVH6800J Front Load...
Need to reverse dryer door on Model #FEFB9200ESO
instructions are available here
thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Feb 06, 2009 | LG WM-2277HW Front Load Washer
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Doors
First Read your owners manual and see if the doors are reversible. They may or may not be?
at one installation we did the washer was not reversible so we put the dryer where the washer was and the washer where the dryer was, customer was very Happy and was Happy to pay $$$
May 25, 2008 | LG WM-2277HW Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Reverse Door
You can't reverse the washer door, only the dryer door.
They don't make the washers reversible because the door latch and wiring harness would have to be relocated to the other side. It just isn't practical from a manufacturing standpoint.
Sorry, Mike
Nov 04, 2007 | Kenmore 43142 Front Load Washer
LG WM0642H Front Load Logo
709 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
