SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
SOURCE: Sony Bravia 40inch how do I remove input icon
Press " i " (info) button on TV remote and on-screen display will disappear.
SOURCE: programming remote to operate Sony Bravia TV
You can find your codes here:
www.tvcodes.com
OR
www.remotecodelist.com
OR
www.remotecontrolsrus.com
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
