SOURCE: Message on Brother MFC
Open door
press Clear/Back key
press *00
press OK
Do not
choose anything for drum replacement. when drum replacement menu comes
up, just press the * and then 00, then just press OK.
that should clear the error message, the printer has a toner life counter that needs to be reset.
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
SOURCE: toner cartridge problem
When you remove the drum & toner unit from the machine, there is a small round window where a beam beams through the toner. block it with a piece of paper. Put them back and print again.
SOURCE: i replaced my brother MFC
Check the toner cartridge, side gears, you can see a reset lever (that lever is very important) show in the next picture.(cartridge new)
