SOURCE: OEL Display not Working on my Pioneer DEH-P7800MP
Sorry can't help, but if you can't fix it and would like to sell it, let me know. I need the parts for an audio project I'm working on. Email: [email protected]. Good luck anyways :).
SOURCE: display problem
Hello, I had the same problem with my 7800, I found R841 was open. Try this.
Sorry for my english, I´m from Argentina. Good luck.
SOURCE: I can't select aux when I plug my ipod into my Pioneer stereo.
I think this can be done with the stereo on but you have to hold down either the e button or 1 of the buttons on the right side of face(not audio)maybe and a menu will pop up and you should run into a screen that ask off on or off you will want it on and then you should be able to access ur ipod by pressing the source button.Hope this helps.
SOURCE: I do not have the wiring diagram for a pioneer deh
If you're installing this the easy way to go is go to like walmart and buy a stereo
wiring harness for your specific vehicle. This plug plugs directly into
your factory plug and has the wires that connect to your pioneer unit
attached to it. All you need to do is match color to color. tracing
wires to splice directly into your factory wiring can be a royal pain,
trust me i've done it and it ain't fun... but for what its worth here
you go.
Red...Accessory
Yellow...power
Black...Ground
Blue w/ white stripe...remote turn on
Blue...power antenna
Gray...Right front+
Gray w/black stripe...right front-
White...Left front+
white w/black stripe...left front-
Purple...right rear+
Purple w/black stripe...right rear-
Green...left rear+
Green w/black stripe...left rear-
SOURCE: How do I remove a Pioneer DEH-P3100
Remove the plastic trim ring, and it reveals a slot on either side for pioneer chassis release keys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
