SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
SOURCE: Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
SOURCE: inside the air is blowing,
Two things; outside does the compressor try to come on? If not you may have a switch\Thermotat problem. Also make sure the breaker to the outside unit hasn't tripped. If it has tripped there may still be a problem after you turn the breaker back on. If it's only the fan that's not coming on outside you will need a new capacitor or fan motor and compressor(if the fan motor is replaced you should have a new capacitor also. If it has been intensely hot your unit might have just gotten overworked. Then resetting the breaker is all that is needed. If you have continuos resettings you MUST call a qualified HVAC Tech.
