Mtd 19 In. 173 CC OHV 3-In-1 Logo
A
Anonymous Posted on Aug 22, 2013
Huskee 21 173cc ohc
It wont start
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
Honda GVC160 wont start OHC cover dented
The cover does have the valves underneath. The cover is sealed with a gasket so carefully pry it off. You can fix the dents, then replace the cover sealing it with RTV sealer if you ruin the seal.
It's unlikely the starting problem is here.
Huskee mower wont start
check the safety switches try and jumper the one on the clutch/brake pedal first with a paper clip
Apr 29, 2012 • Garden
2answers
Hi. I have a huskee 15.5 riding mower that wont start. It was running. I replaced the front drive belt and now it wont start. I have replaced the battery, air filter, and spark plug. it turns over fine...
fri-st is to check your spark, than your going need to check for compression, than go to carburetor, when you replaced your belt you may have disconnected a safety wire. try this frist let me know
Oct 06, 2009 • Garden
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
