Hobart A200 Stand Mixer Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A-200 Problem?? Apparently the electric wire coming into the back on the machine plugs into a small circuit board, the male prong aparently touched the copper wrap that makes the motor spin and has blown, the motor i am told is shot. Do you know where I can find a use one to slide back into, I just put $500 dollars in maintance and just had it powered coated??
Anonymous
Level 2:
  • Expert 135 Answers
  • Posted on Apr 11, 2009
Anonymous
Expert
Level 2:
Answers
135
Questions
Helped
110094
Points
425
Hi Adam. Easy part first! Check locally for an electric motor specialist, who can rebuild (rewind) the stator for you. If no luck there, check out eBay for a complete motor (stator and rotor), they come along fairly often.
If this solution has assisted you, please rate it. ricardok45
PLUG IN MY VIKING 1000 WATT MIXER AND NOTHING HAPPENS, WHAT IS WRONG?
If the motor shows continuity (Yellow and Blue wires), then you don't need to replace the heat protection fuse. Check the small circuit board in the plastic housing with the wires going in. Use your ohmmeter across the small 220 mfd capacitor to see if it is shorted - which was the problem with my daughter's VSM700. Replace with any small 200UFD capacitor that is over 10VDC and orient the cap so the negative lead goes to the half moon of the silkscreen on the top of the PCB.
Was working few years but doesn't start at all.It being a month without using it, then trying to turn it on but nothing.No issues before. Watched DIY videos just replaced its Phase board, nothing
You really need to get a Multi meter and follow the power, you have replaced the phase board so we can probably discount it being that.
First check that the switch contacts behind the black control board are really touching when you move the speed control lever to turn the mixer on.
Next the cable, do you have continuity from the wall plug to the control board on phase & neutral, (Check green earth wire as well for the sake of safety) that will be the black wire and the white wire on the 2 lower plug in contacts on the black control board at the back.
Next remove the carbon brushes, do they have reasonable length and most importantly are they fitted correctly with the corner key aligned with the blocker at the bottom of the brush holder.
Next with brushes out check for field winding continuity. On the other side of that black control board to where the power comes in there will be a red wire and a white wire that disappear into the motor housing. One of the wires will have a circuit to one of the brass brush holders and the other wire will have a circuit to the other brush holder. The resistance of both of those circuits should be pretty much identical.
After you have done those tests you should begin to have a clue as to where the problem lies.
1helpful
KitchenAid 5kpms
OK you have mains voltage across the black wire and the white wire on the 2 bottom terminals on the left side of the speed control plate. You are certain that the carbon brushes are in the correct way around with the shaved off corner lining up with the blocker in the brush holder. Are the switch contacts touching when the lever is moved to position 1. They are on the inside of that black control plate. If they are touching and still no go you need to check that the fields have a circuit. You notice that the black and the white wires cone from inside the machine, there are 2 more going inside as well. Remove the brushes and check for a circuit between one of those other 2 wires to one of brush holders and the other wire to the other brush holder. If that's OK you are pretty safe to change the phase board that is above the black control plate. It has about 4 wires coming out of it. The control plate has wire colours written on it beside each terminals so there is no chance of a mistake if you can read.
I replaced one of the control handle that simply had the black knob broken off. Kitchen aid mixer was working perfectly up to then. When I put it all back together it won't turn on at all! I touched n
There should be a Micro switch that is plugged out or broken,you will find this switch on the arm if it dont connect or make contact the machine will not work.There will be 2 wires on the switch will be small becareful can break easy.
Jan 06, 2014 • Food Mixers
Washing machine cause electrical short circuit during pumping of hot washing
Maybe replace pump and check positive wire to pump is not touching casing anywhere on machine
Sep 21, 2013 • Food Mixers
Getting an electrical shock from the outside of my Kitchen Aid power stand up mixer. No visible break in cord.
But!!!! there could be a break in the grounding wire inside the back of the mixer motor head, it is easy to check. face the rear of the mixer and look at the top you will see a small screw, remove it and gently lift the rear cover up and out muck more up than out (you could break off the mounting ears on the bottom of the rear cover) then look at the plug wires, white and black wires should be attached by clips to speed control switch the green grounding wire should be attached to the mixer frame with a screw, if it has come off then put it back on, the screw should have fallen out when the rear cover was taken off if the screw has come out, it may just be loose also so use a phillips head screw to tighten down. please let us know if this helped or you need more help there may be a more serious electrical problem that needs to be dealt with.
1helpful
KitchenAid KSM90 mixer wont turn on, already replaced phase board
Did you play with the Brushes??? If you did you have to make sure that they went back in the correct way or they won't be touching the armature and the mixer will not operate untill the brushes touch the armature. If you did nit take the brushes out at all. then your problem is the flag connectors are not in the correct terminals. 9_15_2012_6_02_40_am.jpg
the other problem is the possibility that when you re-installed the speed board that you now have to tune the mixer by adjusting the screws on the top of the speed board.
1helpful
Fails to run
The governor should move back and forth as the speed control goes from speeds 1 through 10. It's purpose is to push on the control plate in order to obtain the different motor speeds.
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
I am getting a lot of distortion feedback when I connect my computer to the mixer but the feedback only starts when the computer is connected to an electrical outlet. I have plugged the computer to a...
Sounds like a ground problem. Try to hook a ground strap or wire from the case of the computers power supply to the ground of the mixer. If it still has noise, try to touch the ground to the bracket of the computers sound card. Most likely, the computer uses a three prong adaptor and the mixer does not. Outlet grounds have voltages which bleed off from motors and other devices, which could cause the 60hz noise. If your mixer has a three prong plug do not plug your computer and mixer in separate outlets with separate grounds or you could fry your system. If you still have problems use a three to two prong adaptor and attach an isolated ground wire on the adaptor for the computer.
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
