The fuse might be built into the cable to the lighterand/or radio. It's called "fusable link", this type of fuse looks like a cable. Or another type of fusable link might be in the fuse box under the hood near the firewall.
You haven't given us much information... You obviously have some sort of feedback and saturation in process. First thing is to unplug ANY signals into the unit including any inserts and see if problem goes away. If it does, start adding them back in. If it doesn't go away with only the main outputs then VERIFY that you are using BALANCED interconnects to your amps/speakers AND that the mixer AND all of these amps/speakers are powered from the SAME receptacle or power conditioner module. If the BARE mixer with only headphones has the problem, then you have a power supply in the mixer that is squeging.
check all connections (speaker wires and rca jacks for shorts) replace them one at a time and listen if the static continues. Sometimes the static is due to a broken solder joint inside the amp either on the input or output connection post. hope this helps
That radio may have a lot of noise on its outputs, there could be a ground mismatch, or other problem. Can you tell us more about the car, the radio, Amps, and anything else involved with this system? Thanks
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
You can buy a used monitor about $50.00 in the US. or You should take the monitor to an authorized repairman. IT IS NOT recommended to fiddle by banging a defective unit WHICH has HIGH voltage running through it.
The static is called "line noise". It happens when there is not a lot of protection between the copper wiring that carries the signals and the outside. One way for manufacturers to save money is to put just a very thin piece of protection around the copper wires, with no insulation. Just copper wiring and a thin piece of rubber or plastic. So that is why you hear the static noise, the wires are cheaply made and cannot keep out the signals they interfere with it...hence the cheap price. Wal Mart is good about giving refunds, bring it back and get a better made system. It might cost a little more but the sound will be what you enjoy. Don't forget to rate this 4 stars before logging out.
you could possibly have a speaker wire shorted out, a bare piece of the wire touching metal somewhere that the insulation has worn. and it would be in the rear speaker wires. you might also check for a blown speaker this could cause the problem also.
Check to be sure you ran the audio wires away from the power supply wiring. I always run the audio down the Passenger side and power to amp on Drivers side. Also check you Ground, and be sure you have metal to metal, no paint obstructing the power.
