sc582 is an inverter error. The coil that heats the fuser may be bad, or there may be a bad connection somewhere. If you go into SP mode and execute SP 5810 to reset the fuser, see if the code comes back. If it does, have a Ricoh technician check the IH coil and the connections for it.
c4000
The Problem: inside the laser unit Polygon motor synchronization problem The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
