Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
need to dis assembly the frame of the tv and take the 3 screens out and cleaned may sure you put this back in the same way you took it o each side is different do not use any cleaner like windex
if you talking about the drain trap, its very easy to clean. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly. Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
just take it to any mobile repair shop ,and he will open the front panel of your mobile and will clean the dust,if mobile body is damaged replace your mobile body.. or : If you know how to open the front panel of your mobile it will save your money,just use clean cloth to remove dust.... ------------------------------------------- Please let me know your feed-back.
the only screens you can clean are located in the throat of the water inlet valve which can be acess from removing the water hoses, dont know where or what screens you could possibly get to be lifting hte top
You'll have to pull the front of the unit off to clean the inside. This includes taking out the screw that are open normally and there should be about 4 screws that are behind the bottom-back panel.
When you open the unit just be sure you get it clean the first time and don't leave any stray fingerprints on the glass. And don't touch the projection lens at all. Use compressed air to blow it off but I wouldn't recommend cleaning it unless it is just filthy and the canned air doesn't work for you.
