Zyxel P660HW-D1 Router Logo
Posted on Apr 11, 2017
Zyxel 660HW-D1 drops wireless connection to second and third comp
I have a problem connecting wireless to a Zyxel 660HW-D1 router with second and third computer. First computer connects and stays connected while other machines connect but then begin to drop the connection regularly. To reconnect I have to 'repair' connection. I have configured the mac address filter for all three machines. The machine that connects well is a laptop. The second machine has identical hardware so I'm pretty sure the problem is in the way I've configured the router. I have 1) enabled wireless lan 2) enabled key autogeneration 3) am using WEP 128 bit encryption
Thanks for any suggestions
5 Related Answers
Anonymous
  • Posted on Apr 30, 2008
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
aysaam
Resolution IT Dubai
  • 541 Answers
  • Posted on May 29, 2009
SOURCE: No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
7 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
8 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
9.Then u can configure the ip address
Regards,
Ayyasam
Anonymous
  • 86 Answers
  • Posted on Jun 03, 2009
SOURCE: ZyXel P-660HW T1 router - sporadic wireless connection
It could be caused by interference by other nearby networks/devices. Try changing the wireless channel.
Anonymous
  • 68 Answers
  • Posted on Jan 07, 2010
SOURCE: I`VE GOT ZYXEL P-660HW-T1 WIRELESS MODEM I BOUGHT
You will have to reset the router to factory settings. There is a small hole in the back, depress the microswitch with a paper clip when the power is on. The default password is 1234. Some of these devices are general, while others are hardwired to work with certain providers. So if, say, this 660 is branded with embarq it is unlikely that you can set the parameters to work with other providers.
I should mention that if you care about security you should not use WEP - a cracker can break an internet connected WEP device in minutes with the right toolset. The protocol has many problems that simply can't be fixed, period. Consider using WPA2 with WPA backcompatability, as allowed by the 660.
Anonymous
  • 157 Answers
  • Posted on Feb 06, 2010
SOURCE: how can i find my wep key for zyxel P-660HW-D3
See the attached manual and look up page 63 where is shows how to get to the wep key information.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
My ex partner set up my internet access using a Zyxel router P-660HW-T1. Now my daughter has purchased a laptop and wants to connect to the internet. Unfortunately, he didn't tell me the security key...
There is a reset button on the back of the router. You have to press it in for about 10 seconds. (While the router is on) This will reset the router to default settings. You will lose all security, and your network will be "Open". You will then have to refer back to the guide in order to setup your network security, and create a new password.
Here is a link to the guide.
ftp://ftp.zyxel.com/P-660HW-T1/user_guide/P-660HW-T1_3.40.pdf
2helpful
Have a wireless router- looking for the network key to connect to the internet from my laptop.
download this ftp://ftp2.zyxel.com/P-660HW-D1/user_guide/P-660HW-D1_3.40_Ed1.pdf and read from page 107 full instructions for setting up your wireless is shown there , if the wireless is already showing when you scan for networks on your pc and all you need is the security key you can find it from the instructions in the manual
2answers
Please I want CD setup router ZyXEL MOD. P660HW-D1 .
The quick start guide for this device can be found here: ftp://ftp.zyxel.com/P-660HW-D3/quick_start_guide/P-660HW-D3_2.pdf
You should be able to do any appropriate configuration with this guide.
Good luck.
Hi, how can i get nat open on my ps3 whit my zyxlel router
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
Use port forwarding to sort out ya problem, find you router, and it will show you what to do.
www.devicemanuals.com/guide/.../ZyXEL/ZyXEL-P-660HW-D1-3-40-User-Guide-TkRjNU9EUT.html - 21 hours ago
User Guide above.
1helpful
Having a connection problem with ZyXEL 660Hw-D1
Did you duy a service. If not buy one. If has have to have broadband.
1helpful
I have a Zyxel 660HW modem/router - I can't access wireless
switch it on, it will search for wireless accespoint in ur network. connect to it and given security passphrase and then ut will connect permantently.
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
