Try disconnecting your Cisco Wap4410 from all other network devices then restart it - it will look for a DHCP server, and when it doesn't find one will choose the IP: 192.168.1.245 ---
Set the TCP/IP settings on your laptop to:
IP:192.168.1.250 / Subnet Mask: 255.255.255.0 / Default Gateway: 192.168.1.245 and connect your laptop ONLY to the WAP4410 using a cat5 ethernet cable ---- you should then be able to load a web config page using internet explorer and browsing to:
http://192.168.1.245
-------- I've paraphrased the following info from the Cisco User Support Forum (User Juunda):
"...If you read the administrator guide it states that the WAP4410N will search for a DHCP server first, if the dhcp request times out then will it default to 192.168.1.245 this is done so with a user friendly plug and play mentality in mind. Best practice would be to give the AP a static IP of your choice and in your subnet/network so the fastest way to configure the AP out of the box is to assign a static IP on your pc/laptop in the 192.168.1.X /24 and directly connect to the WAP4410N and give the WAP a static IP, define your gateway, DNS servers and then implement it into your network..."
