Samsung LN-T4665F 46 in. LCD Television Logo
Ray Hamel Posted on Aug 25, 2013
Why does my tv click when I turn it on? - Samsung LN-T4665F 46 in. LCD Television
Hi my tv sounds like it start but it wont como on i change the power board but still did the same what could it be thanks
Samsung 52" TV Repair - Won't turn on Clicking Sound ...
? 9:37
https://www.youtube.com/watch?v=2WpSJy_kANs
Apr 13, 2012 - Uploaded by Kathy Burton
It makes a clicking sound several times before it turns on, seems to ... Samsung 52" TV Repair - Won't turn on Clicking Sound ...Maybe it took a little longer than that, but I was happy. ... My TVworks like new. ... Samsung No Start / Clicking Repair - 52" LCD HDTV - Duration: 8:26. by clipdan 169,453 views.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and ... hi my tv flashes red and bluebut wont turn on.
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
Tv clicks when trying to plug it in and won't turn on
begins working for alomentacion source that can be damaged or filteos the same regulatory
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
1helpful
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
3helpful
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
1helpful
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
