Tip & How-To about Kodak EasyShare V530 Digital Camera
Lens not retracting on digital camera.
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Kodak EasyShare V530 Digital Camera Logo
lens will not retract. camrea frozen my camera will flicker on and off and the lens will not retract. it is a kodak M763, first time this has happened.
lense will not retract even after camera has been charged
a570is
lens doesn't retract when cover hits it. Only way to get lens to retract is to take out battery, put it back in, and then the lens slooooowly retracts, but will bounce back out if cover is closed quickly...Going to Europe in 2 days..should I buy a new camera???
The original problem was a camera with jammed lens mechanism or faulty lens motor. I think the camera had been replaced.
The following post is directed to new users following up on this thread, as the original problem had already been sorted:
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
