SOURCE: my computer (emachines T5212) beeps at me
Resetting the bios should stop the beeps, 'JBAT1' terminal from pins 1-2 to 2-3 for a few seconds then back to pins 1-2. Get the pc running again on your onboard graphics or whatever it was, but enter the bios (f2 or DEL on start up)as you will have to reset time; also to dissable onboard graphics and enable your AGP slot as primary graphics controller as it may be dissabled in the advanced bios menu. Make sure you havent got an intruder device lead from your side panel as this could also be the beep which has to be cleared also in the bios
SOURCE: pc beeps five times when swtched on
PC beeps are usually memory-related problems. make sure you are using the right memory for your computer. the specs should be a DDR2 DIMM 240 pin PC2-3200. what specs do you have?
also do you have two 1G memory sticks or just one 2G memory stick? it may be that your computer doesn't accept a 2G memory stick but rather 1G memory sticks. good luck.
SOURCE: HP Pavilion DV6000 1 long
1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
Check out this link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=19409&product=1842189&docname=c01087277#c01087277_identify
You may be able to get HP to repair it for you.
Good Luck.
SOURCE: Need a replacement graphics card for HP Pavilion
Hello there
I would suggest to use the ge force 6200 it is very compatable with the hp pavillion series
it will cost you about 60 dollars andcomes with a 2 year warranty Most local computer repair shops or computer stores will have this card ok
I hope that this is very helpful for you.
Best regards michael
Testimonial: "Much appreciated, thank you"
SOURCE: I have a HP dc7600 SFF. Tried to Install 2 graphics cards no vid
The dc7600 SFF only comes equipped with a 240 watt power supply. I think this may be causing your problems.
I am currently looking for a graphics card for the same comp with the HIS ATI HD 4350 in mind, but the website states that a 300 watt power supply is recommended.
