Question about Canon imageRUNNER C3200 Copier
Error Code E00002-01c0
Getting error code E00002-01c0, anyone know what that means???
  • huey Apr 13, 2009
    hi,
    Can I put a used drum from another machine and what should I do after put in used drum unit? I have a c3200N how can I calibrate scanner/ copier?
    thanks,
  • brandon372 Apr 16, 2009
    Thanks for the info, new drums on the way!
    Sniper:
  • 153 Answers
If you use a second hand drum it wont fix your error code, the error code you have is because it has reached its life the drum unit and if you put in a second hand one it will not reset the drum counter so the machine will still think it has the same drum in it. new drums have a little fuse they blow that is how the counter is reset.
canon tech
Posted on Apr 16, 2009
  • 168 Answers
You probably mean E000020-01c0 bad yellow drum codes in order 01Y 02C 03M 04B
Posted on Apr 10, 2009
  • Anonymous Apr 16, 2009
    you can put a used drum in it wont reset the count to 0 but if the drum is good it will work do it all the time
0007
4 Suggested Answers
6ya staff
SOURCE:
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
Anonymous
  • 67 Answers
SOURCE: ERROR CODE E000020-01b0
your yellow drum unit is bad replace it if the error ship to 000020-02b0 replace all your drum unit because all the units could be bad but the machine will show one at a time as you replace the drum units
Posted on Jun 19, 2008
dmbeal
SOURCE: Canon PIxma MP620 Error 6C10 - Please help!
I got the same code on my ip3600, and stumbled across a quick fix which may work for yours.
1. Turn power off
2. Open cover as if you're going to change a cartridge
3. Turn power on
4. When printhead is in position to change cartridge, close the cover
That's all I did, and it seemed to work.
Posted on Feb 11, 2010
Have an FO error on frigidaire dishwasher. anyone knows what this error means?
Hello Ermellina, thank you for your post!
If you are getting an error code "F0" on your Frigidaire dishwasher, it usually means that you are experiencing an issue with the water level. To clear the error code, you can reset your dishwasher. However, since you have already turned off the circuit breaker, at this point, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis. Best - Z
Sep 14, 2014 | Frigidaire Dishwashers
We are getting an error code of "PF" and can't
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
0-=0
Oct 31, 2010 | LG WM3431 Front Load Washer / Dryer
OBD Error Codes
I get an error code of 052 on the A/C control unit in my 2000 Mercury Grand Marquis. Does anyone know what this error code means?
May 26, 2010 | 2000 Mercury Grand Marquis
Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Mar 12, 2010 | Dell Inspiron 13 Notebook
Error Code "H" and "4"
The meaning of the H4 code is a fuser warm up failure. This means that the fuser is not coming up to temperature as it should within a certain amount of time. This code comes up occaisionally on the AL series for some reason. The fuser unit in cose you don't know is the part that gets hot and is located right where the paper exits the machine. If the code does NOT reset then the part most common to fail is either the thermal fuse or the heater lamp itself.
It all depends on how often the code comes up. Make sure that the machine is not to "cold" at start up. Install a power filter between to the copier and the power outlet to make sure your not getting any line noise that could cause the flase errors. That is about it.
Jan 11, 2010 | Office Equipment & Supplies
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
E100 error
Hi Paikin,
The error code 100 - Excessive Repeat Protocol during Transmission. Causes
1. Poor line condition.
2. Low transmission level.
3. Echo on the line.
Try reducing transmission spped.
Rgs
S88
Dec 18, 2008 | Canon LaserCLASS Fax 710 Printer
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
F3 error code
I keep getting an error code of F3 for my Magic Chef stove model CER3520AAL does anyone know what that means and how to fix it?
Help!!!
Dec 12, 2007 | Kitchen Ranges
E90 Error Code
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
Canon imageRUNNER C3200 Copier Logo
724 people viewed this question
Clive
Clive
old marine
old marine
Ekse
