SOURCE: maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
SOURCE: Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge
and the front panel to the front shroud assembly. Do the same to the two
screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of
the cabinet by grasping the upper part of the front panel posts and
pressing in on the outer edges then twisting it inward. Once the front
panel posts are released from the cabinet, tilt the front panel away
from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
SOURCE: my maytag neptune washer stopped working and
It could mean flood error.if it has stopped full of water & it wont drain out.The pump might be blocked or jammed with hair pin or other debris.
If you want to DIY the issue Google "Sticky: Neptune TL Washer FAV6800AWW" you can get the Service Manual from that site to help you DIY the fix along with forum guidance.
I discuss the troubleshooting the Left Hand Lid Lock in that sticky.
I can't find my repair notes on this forum no Sticky and no Service Manual.......D*ick
