Sierra International 18-3090 Marine Neoprene Impeller with 6 Fins for Johnson/Evinrude Outboard Motor () Logo
JOHN ADAMS Posted on Aug 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Match year of manufacture for Evinrude Boat Motor with Serial Number: 6202DJ03489
Larry
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Sep 11, 2013
Larry
Expert
Level 2:
Sergeant:
Answers
288
Questions
0
Helped
55642
Points
528
Mumbles
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 03, 2016
Mumbles
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
5568
Points
27
Model 6202 comes up as a 1972 Evinrude six horse motor.
Have evinrude outboard serial number 1591802140. What is model number and year?
Hey Jan,
The model number/serial number should be on plate attached to the engine mount...You need the model number to determine year.
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 25, 2017 • Boating
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Yr Evinrude boat motor was made
going by the model number 6RCRM the year is 1984
here's a link to the codes
http://www.iboats.com/basics/johnson-evinrude-80-later.html
Sep 05, 2016 • Boating
1helpful
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
Evinrude Outboard Motor Model Numbers
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 • Boating
I have an older Evinrude boat motor with a serial number of 15918-04242 that I don't know the year or horsepower of ??
google eninrude site and see if there is a page of serial numbers that will cross to year and horse power
May 27, 2015 • Boating
What year is this evinrude 135 hp boat motor? serial #j0007646
To have the year of your engine, we'll need the engine typenumber, not the serial number...
2answers
Where can I find the serial number on my Evinrude 20H motor?
There is a plate or sticker on the Port transom bracket or on the steering bracket ( between both transom brackets ).
On very old engines the plate is rivetted on the steering bracket at the front of the engine.
If you can't find a plate or sticker anymore, there is a aluminum 'freezeplug' with the serial number stamped. You'll find that plug in most cases at the starboard side of the engine block near the cilinder head, or on the top of the cilinder block.
Evinrude outboard motor serial number c7108106
The Manual Store also has some useful boat motor model year lookup data:
Boat Motor Model Year Lookup Guide
Jun 30, 2013 • Boating
Top Sierra Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Sierra Boating Expert? Answer questions, earn points and help others
