Hi i got a hoover hnl71463d washing machine where does the fresh watet pipe go on the hot or the cold as it only has 1 on the back of the machine thankyou
If it has only one water supply pipe the answer is clearly no as you will be aware ;-0)
If it needs a hot and cold supply, but you do not have a hot supply convenient, you will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Hoover washing machine This video will show you how to keep your soap draw clear
and how to service the parts
Please remember to subscribe to our YouTube channel for all
appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
First plug off the wall. Before connecting the "hoses" (both hot and cold) to the machine inlets see that the inlet is clean. Connect the outlet hose to the standpipe, not too deep. The outlet hose has to be about 3 feet above ground level; there is a water level mark behind the machine. Both the inlets should be well screwed in, noting the threads of the inlets
You said the water was gushing.....into the machine? Fine .....what next.......post back.
