Our Maytag Neptune Washer is making a funny sound, near the end of the cycle. It is sort of a scccrrrccch scccrrrccch sound. And in the window where the countdown of minutes show, it has a code ND.
What does that mean, and what should we do?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
How difficult is it to replace the pump? The ND error light appeared, water has drained and need to somehow check the pump. Any suggestions?
WATER STILL IN WASHING MACHINE, AND ND ERROR APPEARS.
