I heard a pop and then the amp did not work. I removed fuse. OK for fuse replacement because purple capacitors (per your previous NAD C370 trouble-shooting solution). Ceramic fuse is T6.3AH/250v BUSS. However, stated on circuit board: T3.15AL/250v (CE) and T6.3AL/250v (others). Is there any important difference between AH and AL fuse type? Anything else a layman can check?
Sounds good; however, no wire observable for this ceramic fuse. So, should I go with the AH fuse, since that's what the amp came with or follow the stated AL direction? Any thoughts?
It worked, we have music! Thanks to FixYa and a special thank you to petraman 7.
