SOURCE: Problem with Cimbali M29 steaming wands
Check the water level, if you remove the top panel you will notice that the steam valve are connected at different heights on the boiler. If the machine has the silver probe remove it and clean.
SOURCE: Can you turn off one of the left or right sides on
1-Cover the buttons on offending side (paper and 1 min to do)
2-Reprogram one side to give it a short dose. (5 mins to do)
3-remove power to group valve (screwdriver and 20 mins to do)
Note if you do remove the power, please leave a note for the crew as they will probably call a technician in to 'repair' it again.
SOURCE: La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
