Question about Freezers
My 3.4 Haier chest freezer suddenly stopped cooling. Plugged it in after 2 months of unuse. Filled cold freezer next day with frozen dinners.It worked for about 3 days. Now, all the food is defrosted and spoiled. The green light stays on and I hear a click every minute or two and the inside is warm. It hasn't been on its side, but I have tilted it about an inch to clean under it. What can I do?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
You have a bad relay or compressor
Posted on Oct 23, 2017
6ya staff
SOURCE:
Anonymous
  • 150 Answers
SOURCE: Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
Posted on Apr 23, 2008
22yooper
James Helmer
  • 828 Answers
SOURCE: Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
Posted on May 16, 2008
Anonymous
  • 124 Answers
SOURCE: freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Posted on Nov 02, 2008
Anonymous
  • 30 Answers
SOURCE: Haier chest freezer HCM050EB stopped working
The click possibly from the overload protector on the compressor. If the compressor feels really hot you can try leaving it unplugged for 24 hours then retry the start. If it continues then you possibly have a bad motor starter or locked up compressor.
Posted on Mar 06, 2009
Anonymous
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
Haier troubleshooting
Does it have cooling coils in the back... or underneath... that might need to be cleaned and vacuumed out???. That is a common problem.. Another thing, check to see if the door is sealing properly.. The next suspect might be the temperature adjustment mechanism that you've been adjusting..
Aug 07, 2014 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Compressor runs but freezer not getting cold
Have the gas checked. If the thermostat pick-up is frozen over that could result in the contents of the freezer not getting cold, but for that there would have to be a build up of ice on the sides of the freezer.
Jan 25, 2011 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
We purchased a small haier chest-type freezer in 2006. It has worked fine until the past week. It seemed to be running normally, but suddenly did not keep the food frozen solid. There was a little ffrost...
You may have a refrigerant leak. First make sure the lid has not warped and leaving an air gap for heat to enter. That's really about all you can do without getting a tech. involved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 01, 2018 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Nov 23, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
240 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
