GE 11242 LED Motion Sensing Night Light with Auto OnOff Logo
A
Anonymous Posted on Aug 27, 2013
Lights seemed to have burned out after 6 months usage.
I have a homebasix quartz heater with 2 heating bulbs., one of the bulbs is burnt out is it safe to continue to use it with only one bulb working? Thanks
Light bulbs can't burn forever, and in reality, incandescent bulbs have a lifespan of around 900 hours. Based on a usage of eight hours a day, a bulb should last roughly about four months. Compact fluorescent bulbs (CFLs) are supposed to last much longer, but this is not always the case. If you have replaced bulbs recently and the lifespan doesn't seem to be all that it should, the cause may be in the fixture itself or elsewhere in the circuit.
Jenn-air dishwasher will not start
it is usually the panel that fails
Which is the maximum duration of the calcium cleaning cycle
Hello Fellow Espresso Maker
We at Expressfix recommend you descale every 6 month depending on water quality and usage. We tell our clients every 6 month to prevent scale build up and proper operational status for normal usage(2-3 drinks daily). Poor water quality leads many future preventable service calls.
Thanks
How do you light the pilot light? if it doesn't have a pilot light how do you light it?
It could be an auto ignite stove. Check the manual. Some of the newer stoves have an electronic ignite to save on gas usage. A pilot light can burn as much as 3 gallons of gas a month.
Sep 04, 2013 • Ovens
Volkswagen touareg burning oil
Why would you think that?
No vehicle uses much oil at all--for over four months
& several thousand miles between oil changes
You have potentially serious oil consumption issues
or leaks
2answers
I have a Mirage Prestige S8 subwoofer. 4 years old. Suddenly nothing....not functioning. No change in usage or location. Any ideas?
Check the status indicator - The LED found on the front panel should be illuminate in blue when the subwoofer is functioning. If the unit is in Auto mode and is not receiving a signal, the light will remain off. Try setting the power switch on the back to ON if in the Auto setting. Post back the status of your LED.
99 firebird light problem
check your wiring harness to breaks and shorts also check to see if water is getting into the turn signal lense through a crack
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
