The best way to change IP address is using vpn service. This is secure and safe solution.
Sahrzad VPN The Best VPN Service to Access Blocked Sites
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch
for a minute and the switch on it..Check the ip-address at Ip-details.com
if your ip address changed .It's Dynamic ip address ....You can change
it many times by resetting the modem...Before changing check your
previous ip ,so that you can know the difference.This is will not work
if your ip address is a static ip address...Static ip will not change
even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip
address...But it's not legal to hide ip address always..It helps to hide
your ip address from hackers..So whenever you need you can hide
ip..Don't hide ip address always .. You can also display your ip from
Canada using proxy,even if you are in USA.
